Earn extra with DOUBLE Points on all purchases!
Sedgwick 571 Floor Standing Morticer Mk2
- Designed for industrial use, manufactured in the UK
- Front mounted table length stop bar, marking out rail included
- Two-position depth stop for haunching
- Single hand wheel controls both table movements
- 1.1kW industrial motor fitted with 13mm chuck
- Will accept 13/16" and 1.3/16" shanked chisels
The Sedgwick hollow chisel morticer is a no compromise UK manufactured machine designed for industrial use. It has a cast iron base, column, table and slide ways to provide a rigid and durable mainframe assembly, onto which is mounted the cast iron chisel headstock and an industrial duty motor. All slide movements are easily adjusted by a single dovetail slide for ease of maintenance. Counterbalanced by a weight, giving fingertip control to the chisel headstock rise and fall mechanism. The 1.1kW induction motor is fitted with a 13mm chuck to accept various sizes of chisel bits. A new style table now has a front mounted length stop bar, and has longitudinal and lateral movement on a single hand wheel control. A marking out rail complete with a turnover stop is now fitted, plus a work clamp with "T" slot adjustment. The angled timber clamp can be adjusted to three positions that give a maximum 180mm width of timber. The head also has a two-position depth stop for haunching. Will accept 13/16" and 1.3/16" shanked chisels. The base size measures 460 x 445mm. Available in single or three phase.
Chisel Stroke | 125 mm |
Lateral Table Movement | 80 mm |
Longitudinal Table Movement | 430 mm |
Max Chisel Size Hardwood | 19 mm |
Max Chisel Size Softwood | 25 mm |
Max Height of Timber | 255 mm |
Model | 571 |
Nett Weight | 170 kg |
Overall L x W x H | 680 mm x 510 mm x 1,720 mm |
Power | 1.1 kW |
Rating | Trade/Professional |
