More deals added in
Have you clocked our Christmas Countdown deals?
Sedgwick MB Planer Thicknesser With Spiral Cutter Block
From £6,459.98 £5,383.32
  • Heavy-duty; cast iron and steel for professional workshop use
  • Spiral cutter block for exceptional clean finish
  • Cast iron tables planed for accuracy and continuity
Customers Also Bought
The Sedgwick MB planer thicknesser with a spiral cutter block is a formidable combination.
The machine is quality through and through, designed for long life and minimum maintenance. Sedgwick build the MB to withstand heavy use in a professional workshop. Solidity and reliability come as standard.
The Sedgwick MB’s rigid base gives it exceptional stability. The precisely machined cast iron surfacing tables do not require removal or tilting when thicknessing. There is nothing to reset on returning to surfacing. The rigid cast iron fence is quick and easy to adjust. It includes an adjustable "Shaw" guard for rebating.
The thicknessing table with extension rollers ensures precise, parallel results. Large diameter steel feed rollers (one fluted, one rubber coated) are gear and chain driven. The 3ph option has 2 feed speeds. Both options feature a braked motor and have a conveniently located emergency stop switch.
The innovative spiral cutter block has 51 tungsten carbide cutters arranged in 3 spiral rows. The cutters have 4 edges and each edge has a very slight radius. The result is a shear cutting action. Like a hand plane with a skewed blade, it produces very clean cuts, particularly in difficult and figured wood grain.
The spiral block offers many advantages. Increased durability: each edge lasts around 10-20 times longer than a HSS knife; each cutter has 4 edges. Noise reduction: spiral blocks are up to 50% quieter with many timbers. Power saving: the shearing action can use 30% less power, reducing the strain on the machine and lowering running costs. Efficient extraction: the size and consistent shape of the chips means more pack into a waste sack. Time saving: the silky smooth surface requires far less finishing and is devoid of the usual fine ripples associated with traditional planer knives.
Available in single phase or 3-phase and proudly made in UK.
  • Easily adjusted rigid cast iron fence
  • Adjustable "Shaw" guards for rebating
  • Separate feed motor, 3-phase option has 2 speeds
  • Braked motor, conveniently located emergency stop switch
  • Available in single phase or 3-phase
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
