Sedgwick SM210 Spindle Moulder
From £4,632.68 £3,860.57
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Robust and reliable cast iron machine, made in the UK
  • 4 speeds, 2 extraction outlets, fitted with shaw guard
  • Available in 1ph 230V or 3ph 415V
The Sedgwick SM210 Spindle Moulder features a cast iron table with anti-friction planed finish and cast iron independently adjustable precision-ground fence plates. A heavy duty steel cabinet base adds to the overall robust solidity of the SM210.
The spindle rise and fall is operated by a handwheel at the front of the machine, and the spindle height read from an adjacent scale. The spindle is belt driven by an industrial motor and runs in “sealed for life” bearings. There are four spindle speeds, changing is a simple matter of re-positioning the belt on the pulleys. There is a viewing panel enabling you to see the set up at a glance.
The machine is equipped with a fabricated steel cutter guard and a robust shaw guard set with hexagonal mountings and steel ratchet handles. Twin outlets facilitate dust extraction from both the cutter well and fence locations. Additional safety features include: automatic braking; starter with thermal overload no volt release protection and lock-off emergency stop; lockable isolator; electronically interlocked door; a footstop and a socket for a power feed unit.
Pre-drilling for a power feed can be arranged; for a quotation, please contact us at email [email protected] or call 03332 406406.
Warranty 1 Year Warranty
