This solid sliding table is suitable for the Sedgwick SM210 and SM255t spindle moulders. The 740 x 300mm cast iron table provides ample support for raised panels, tenons and end grain moulding. Precision roller bearings run along a solid steel bar ensuring a smooth run along the 900mm stroke. The table includes a mitre fence with 90° to 45° adjustment, repeat stop and strong material clamp.
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly Business Services team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
