This Spindle Moulder Tenoning Hood replaces the standard hood and fence. It should be used when the required tooling has a greater diameter than the standard hood can accommodate. Particularly when running tenoning discs. The hood is suitable for the Sedgwick SM210 and SM255t spindle moulders. The can be used with tooling up to 350mm diameter and is provided with a 100mm extraction outlet.
For tooling up to 350mm diameter (tenoning discs)
Replaces standard hood on Sedgwick SM210 and SM255t
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly Business Services team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
