From £3,492.00 £2,910.00
  • Powerful, accurate, reliable and simple and safe to operate
  • Large cast iron table provides stability and absorbes vibration
  • Heavy-duty steel cabinet, built in dust port
Customers Also Bought
The backbone of any joinery workshop is its sawbench. The saw bench should be powerful, accurate, reliable and simple to operate. The TA315, made by Sedgwick, is designed and built with all these requirements in mind. The rip fence is aluminium section, allowing for two working positions (ripping and angled ripping) and for movement fore and aft in relation to the sawblade to suit different operations. It is fixed to a heavy duty cast iron mounting bracket for rigidity, and has integral micro adjustment. The assembly runs on a nylon roller, gliding easily across the beds, and is supported by a 40mm diameter solid steel bar for rigidity.
The cast iron table incorporates ¾” T slots either side of the saw blade, and the machine comes complete with a 6” Protractor Scale. Also included is a fabricated steel Cross Cut Table designed for cutting mitres and compound angles, end trimming, squaring, dividing and trimming. The table is supported on the RHS by precision ground, case hardened bearing rollers running on a 40mm diameter solid steel bar, and on the LHS by a cast jib. The large cast iron table mounted on a heavy duty steel cabinet provides maximum timber support and a stable and accurate base for anchoring the spindle, rise and fall, and tilt mechanisms. The spindle is powered by a high efficiency IE2 industrial rated motor via a twin belt drive, and features large diameter saw flanges for blade stability. It runs in ‘sealed for life’ bearings mounted in a cast iron housing, and requires only minimal maintenance.
Rise and fall and tilt mechanisms are square thread screws operated by handwheels at the front and side of the machine. Both are easily accessible.The TA315 is available fitted either with a 620mm or 1,220mm sliding table, designed for cutting mitres and compound angles, end trimming, squaring, dividing and trimming. A large cast iron table mounted on a heavy-duty steel cabinet provides a stable and accurate base for attaching the saw blade mechanism. Fitted with a braked motor and emergency stop switch and available in both single and three phase models. A British made legend.
  • Braked 3.0kW 230V 1ph or 415V 3ph motor
  • Emergency stop foot switch
  • 620mm or 1,220mm sliding table options, factory fitted upon ordering
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
