2 in 1 by name, 2 in 1 by nature. The FinishPRO® 2N1 gives you the options of either brad nailing and stapling in one tool; versatility that only requires loading your choice of fastening into the magazine. The FinishPRO® 2N1 takes SENCO AX brad nails, available in four lengths from 15 to 32mm. Alternatively the L staples offer a choice of five lengths from 12 to 25mm. The FinishPRO®2N1 has a wraparound resilient rubber grip for comfort. At only 1.1kg it is lightweight allowing you to use it for extended periods without experiencing fatigue. It features an adjustable depth-of-drive to easily get the right result when driving into materials of different hardness. The rear exhaust directs air in the right direction, away from your workpiece. The low load indicator shows when it’s time to reload. The tip features a non-marring bumper pad to protect surfaces.
The SENCO FinishPRO® 2N1 kit comes with 10m of air hose, a robust carry bag, connector set and 10,000 15mm pins.
