Shaper Upcut Spiral Cutter 8mm Shank
- Ideal for intricate cuts and finer details
- Solid carbide composition stays sharp longer
- Great results in a wide variety of materials
Shaper SYS1 Customisable Storage CaseSpecial Price £61.20 £51.00 was £72.00 £60.00 Save £10.80 £9.00
Shaper Essential Bit Set in Micro Systainer Set of 3Special Price £84.16 £70.13 was £99.00 £82.50 Save £14.84 £12.37
Shaper Engraving Cutter 8mm ShankSpecial Price £23.80 £19.83 was £28.00 £23.33 Save £4.20 £3.50
The spiral upcut design lifts waste out of the cut, at the same time helping keep the Shaper down on the work surface. These solid carbide cutters ensure a very clean fast action, greatly reducing tearout and help ensure a smooth finish. The design gives a shear cutting action with rapid waste removal. Available in either 3mm or 6mm diameter.
N.B please ensure your workpiece is securely clamped when using upcut bits.
Shank Diameter | 8 mm |
