Shaper Clearing Router Bit 16 x 16mm 8mm Shank
109289
From £159.00 £132.50
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 28th Mar
  • Solid carbide triple flute cutter for roughing cuts
  • Removes material in a fraction of the time compared to a std bit
  • Take 12 mm roughing passes
  • For all pocketing operations in a wide range of materials
  1. Shaper Clearing Router Bit 16 x 16mm 8mm Shank
Total:
£316.00 £263.33
This speciality solid carbide router bit is designed to make fast work of roughing cuts, removing material quickly and cleanly. This bit will change the way you work with your Shaper Origin. With a diameter of 16mm it will make short work of all your pocketing operations. The three-flute geometry reduces load on the spindle, decreases heat build-up, and keeps your cutter edges sharp and clean through hours of cutting.
Overall Length: 65 mm
Shank Diameter: 8 mm
Cutter Diameter: 16 mm
Cutter Length: 16 mm
Geometry: Clearing, Spiral, 3 Flute
Material: Solid Carbide
