PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Shaper Tools’ approach to handheld CNC routing will change the way you work. Features include a screen, on-tool design ability, automatic cut correction and more.
Simple
The Shaper Origin is incredibly easy to use. Just set up your workspace using the Shaper Tape provided, the Origin scans your workpiece and you are ready to add your design and start cutting.
Versatile
The Shaper Origin can be used for an array of different jobs; routing, joinery, flooring, engraving and much more.
Compact
Able to fit into a handy systainer case, the Shaper Origin can be easily transported from workshop to site.
Efficient
Able to make intricate, accurate cuts in minutes, the Origin guides you so you can work much more quickly than you would when cutting unaided.
Support
All Origin owners will have access to the Shaper Hub. Thousands of designs are stored here, some uploaded from other Shaper customers. Shaper Tools also have a dedicated phone line if you need assistance with your unit.
Book your Shaper Origin demonstration
Want to see how precise and easy to use the Shaper Origin is? Our experts will be happy to provide a live demonstration either in person or via video call. This is a great way to see the machine in use before placing your order!
The Shaper Origin puts CNC routing into your hands, literally at your fingertips. This handheld precision CNC router offers unparalleled accuracy, flexibility and efficiency.
Bring all the benefits and advantages of CNC routing into your workshop. Packed into a Sys 5 T-Loc Systainer case the Shaper Origin comes without the large footprint of a traditional CNC machine or restraints on the size of the workpiece. Being handheld, the Origin has no table or gantry making it perfect for small workshops where space is premium.
Take CNC routing to the job, work onsite on any size of project; on floors, in kitchens, onboard boats, anywhere.
The Shaper Origin saves time spent in producing templates, the template is stored in the machine’s memory, allowing you to get straight on with the job. This machine offers limitless possibilities. Create complex joinery, intricate inlays, fine engraving, decorative parquet flooring, lettering and sign writing
Like any CNC machine, pre-programmed computer software dictates the movement of the tool. Origin features precision X, Y and Z axes with automatic tool tip detection. The screen displays the path of the design for you to follow, the really clever bit is the full auto correction for the movement of your hands guaranteeing precise results.
The on-tool CAD (Computer Aided Design) features means you can draw basic shapes right into the Origin. There’s also the option to import more advanced and technical drawings to the machine via a USB stick, or wirelessly.
The inclusion of the Workstation offers vertical and horizontal workholding capabilities and enables you to secure small and difficult-to-hold workpieces. The Workstation is ideal for making perfect mortice and tenon joinery, box joints, dovetail joints and more. Designed to align and clamp your work with speed and precision it opens up another range of possibilities.
This package includes the Shaper Pro Service, which includes the following: 2 Year Warranty; Dedicated Live Phone line direct to Shaper and Instant Tool Replacement (after discussion if Shaper cannot fix the tool).
The Shaper Origin comes packed in a SYS 5 T-Loc Systainer with: 3mm Up-Spiral router bit, 6mm Up-Spiral router bit, 60° V engraving router bit, 2 x rolls of shaper tape, 2m extractor hose with 57mm OD nozzle and wrenches.
NB. This tool is only available for delivery to mainland UK
