Shaper Up-Spiral Flat Router Bit 8mm x 35mm 1/4" Shank
- 35mm depth of cut length, use more of Origin’s Z-axis travel
- Triple fluted, solid carbide stays sharp longer
- Suitable for a wide range of materials
- Use for both roughing and finishing passes
A solid carbide cutter with 35mm depth of cut allowing you to take full advantage of more of the Shaper Origin’s Z-axis travel range. Three flutes provide cutting advantages in a wide range of materials, from foam to hardwood. Increased pass depth will make your Origin projects more efficient without compromising on cut quality or stability. The shaft is marked for exact collet clamping to save time during bit changes.
Overall Length: 85 mm
Shank Diameter: 8 mm
Cutter Diameter: 8 mm
Cutter Length: 35 mm
Usable Length: 47 mm
Geometry: Upcut, Spiral, 3 Flute
Material: Solid Carbide
D = Overall Diameter | 8 mm (5/16") |
EAN Barcode | 859790007429 |
Shank Diameter | 8 mm |
X = Depth of Cut | 35 mm |
- Standard Delivery* - Free
