Shaper Up-Spiral Router Bit 6.3mm x 25.4mm 1/4" Shank
- 6.35mm diameter with 25.4mm depth of cut
- Solid carbide composition stays sharp longer
- Great results in a wide variety of materials
The Shaper 6.35mm x 25.4mm (1/4"x 1") Up-Spiral Bit instantly clears waste out of the cut. Made from solid carbide these cutters ensure a very clean and smooth fast action, greatly reducing tearout, leaving a smooth finish, and is extremely durable.
It has a 1/4"” shank with the added benefit of a longer overall length and a longer cutting length for deeper passes and improved stability in deep channels.
N.B please ensure your workpiece is securely clamped when using upcut bits.
Overall Length: 63,5 mm (2.1/2")
Shank Diameter: 6,35 mm (1/4")
Cutter Diameter: 6,35 mm (1/4")
Cutter Length: 25,4 mm (1")
Geometry: Upcut, Spiral, 2 Flute
Material: Solid Carbide
D = Overall Diameter | 6.35 mm (1/4") |
EAN Barcode | 859790007382 |
X = Depth of Cut | 25.4 mm (1") |
- Standard Delivery* - £4
