Shokunin Dozuki Universal Saw Blade
- Replacement blade for Shokunin Dozuki Universal Saws
- Impulse-hardened teeth for precision and durability
- Rustproof nickel plating for corrosion resistance
- 0.3mm thick blade with a 1.5mm tooth pitch
- Stiff spine for stability and a 50mm depth of cut
- Suitable for both rip and crosscuts
The Shokunin Dozuki Universal Saw Blade is a replacement blade for the Shokunin Dozuki Universal Saw. Its versatile and high-quality blade is designed for both rip and crosscuts. Its impulse-hardened teeth ensure precision and durability, while the rustproof nickel plating protects against corrosion. The blade's 0.3mm thickness and 1.5mm tooth pitch allow for smooth, effortless cuts, leaving a clean finish with minimal effort. The stiff spine provides stability, enabling a 50mm depth of cut, making it ideal for intricate woodworking tasks.
EAN Barcode | 5052511133994 |
- Standard Delivery* - £1.99
