A replacement or spare blade for the Shokunin 240mm Kataba Japanese saw. The teeth have three cutting edges and a unique profile deigned to cope with soft wood, hard wood plywood etc. With a 1.9mm tooth pitch it offers fast progress through the timber and leaves a very clean cut surface. Easily changed by simply loosening the locking screw on the handle, remove the old blade and replace it with the new.
Shokunin
Shokunin Blade for Japanese Kataba Saw - 240mm
| Blade Thickness | 0.60 mm |
| Additional Accessories | Yes |
| Kerf | 0.85 mm |
| Length of Blade | 240 mm |
| Tooth Pitch \ tpi | 1.90 mm \ 13.5 tpi Crosscut |
| EAN Barcode | 5052511101870 |
