Shokunin Retractable Saw blade
- Replacement blade for Shokunin Retractable Saws
- Impulse-hardened teeth for long-lasting sharpness
- Rustproof nickel plating for enhanced durability
- 80mm blade that fully retracts into the handle
- Handy pocket-sized saw for trimming or modelling
- Suitable for wood, plywood, PVC pipe, and bamboo
The Shokunin Retractable Saw Blade is a replacement blade for Shokunin Retractable Saws. It is perfect for fine trimming and modelling tasks. This blade features impulse-hardened teeth for long-lasting sharpness and a rustproof nickel plating for enhanced durability. The 80mm blade fully retracts into the handle when not in use, protecting it from damage and making it easy to carry in a tool bag or pocket. With a tooth pitch of 1.3mm (19.5 TPI), it cuts quickly and smoothly on the pull stroke, making it suitable for wood, plywood, PVC pipe, and bamboo.
EAN Barcode | 5052511133963 |
- Standard Delivery* - £1.99
