Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
Crafting excellence since 1922
For over a century, Sjöbergs has been a symbol of excellence in crafting professional benches. Handcrafted in Sweden using FSC-labelled wood and adhering to strict environmental standards, each bench ensures superior quality, durability and sustainability.
Choosing a Sjöbergs bench means investing in time-honoured craftsmanship you can trust.
Buy with confidence
This bench is covered by the Sjöbergs 10 Year Guarantee.
FSC certified, timber is sourced from environments that are responsibly managed and meet the highest and social standards.
Sturdy construction
Robust underframe made from Scandinavian pine for durability and stability.
Hard Nordic Birch top
Built to last a lifetime of normal use.
Versatile vice mounting
Includes two vices with four mounting locations for flexible use.
Double row of dog holes
19mm (3/4") dog holes running from each vice location for versatile clamping.
The sturdy under frame is made from Scandinavian pine and with the hard Nordic birch top the bench is built to last a lifetime of normal use. A double row of 19mm (3/4") dog holes run from each of the four vice locations, giving an endless opportunity to clamp your work. There are four mounting locations for the vices allowing you to configure the vices to best suit your working preference. Both vices can be mounted on the front for heavy-duty clamping or one at either end for clamping in two positions and maximum clamping distance. The Nordic bench is equally suited to right-handed people and left-handed people. 4 steel bench dogs are supplied as standard with a plastic coating that helps protect edge tools. The bench dogs are reversible for thin work pieces. Nordic benches can also be fitted with the accessory cupboard and drawer kit (0042) and the optional Holdfast (ST03), supplied as a pair, which can be located in any of the dog holes on worktop or in the holes on the front legs of the bench. Worktop area: 1,340 x 500mm. Please note: available as bench only or complete with storage module. FSC certified, timber is sourced from environments that are responsibly managed and meet the highest and social standards.
Note:
Sjöbergs recommend that you keep your workbench where the humidity is between 40 & 55% all year round. Please see the care instructions on the downloadable documents for more information.
