This mini sandblaster or air eraser has a solid-feeling metal body, with a comfortable grip. Roughly, the same size as a standard airbrush the mini sandblaster is easy to manipulate for fine detail work. It works well with any small compressor, requiring between 45 to 60psi for best results. The mini sandblaster features a single action trigger and a 0.5mm nozzle.
The mini sandblaster removes rust deposits, oxidation residues, paint and can easily reach into difficult spots. Use it freehand or with a stencil to etch onto glass, or metal, or give a matt finish to glossy surfaces. It will work on different materials like metal, wood, synthetic materials and glass. For model making, use the sandblaster to add distressed or ageing effects for greater realism. For model makers, handcrafts and hobbyists.
This kit includes a mini sandblaster with 15cc gravity feed cup, 1/8 BSP braided rubber air hose (1.8 m), 1/8 BSP male to 1/4 BSP female adaptor, 150g of 220 grit aluminium oxide abrasive, face mask and hanging bracket, supplied in a storage box.
Inlet 1/8 BSP
Rating Home/Light Trade
Additional Accessories No
Model SP70
Operating Pressure 45 to 60 psi / 3.1 to 4.1 bar
EAN Barcode 5060252029414
