The SprayCraft SP66 Airbrush & Compressor Kit is very easy to set up and even easier to use.
The maintenance free, oil-less air compressor is compact, portable and designed to neatly store away when not in use. It has a maximum working pressure of 50psi and is fully adjustable allowing traditional spraying at lower pressures, or spraying metallic paints at higher pressure.
The compressor’s case features an integral handy airbrush holder. The kit includes a SprayCraft SP65 gravity feed, dual-action, airbrush with 2m of braided hose. Gravity feed airbrushes require less air pressure as gravity helps draw the paint to the tip.
The SP65 airbrush comes with a 7cc fluid cup with lid and has a 0.35mm nozzle. It is suitable for standard and metallic colours.
High performance airbrush and compressor kit
Compact, oil-less and maintenance free compressor
Gravity feed dual action airbrush
Fluid control knob for easy adjustment
Sprays light to heavy viscosity media
Exceptional atomisation and accurate spray control
