Built for professional use, theis Stabila electronic level features IP65 protection against water and dust. A high quality level with an electronic inclinometer, it's an ideal choice for any trade. The electronic inclinometer has a dual display allowing you to read from both the side and the top. The display automatically rotates for overhead measurements. In low light conditions, the touch of a button will illuminate the display. The unit features audible signals for horizontal and vertical measurements when there is no line of sight. You can select the display to read as an angle in degrees, a percentage and in mm/m or in/ft. The unit has an automatic switch-off function and uses two AA batteries giving approximately 150 hours run time.
The body of the level is an extra-rigid rectangular alloy profile with reinforcing ribs, providing high resistance to deformation. The protective end caps are removable for measuring flush into corners. A special coating protects the level against dirt, whilst rubberised hand-holes make for easier handling.
Accuracy of electronic module: at 0° and 90° is 0.05° between 1° and 89° is 0.2°
Accuracy of spirit level: 0.029° or 0.5mm/m in both normal and upside down positions
