Stanley 3-in-1 Saw
Stanley 3-in-1 Saw
The Stanley 0-20-92 is a multi-purpose 3-in-1 Saw set which offers the functionality of 3 different blades in one space saving design universal pull saw blade, metal saw blade and compass saw blade. It has an anti-slip ergonomic bi-material handle for optimum user comfort, the turn knob allows the user to conveniently store all three blades, switch blades, and tilt each blade into 6 different positions. The main blade utilizes a pull saw tooth configuration which is less likely to jam or bend while in use. Supplied with the following blades:250mm / 10" aggressive tooth 11 teeth per inch universal wood saw blade cuts on the pull stroke perfect for general woodwork and pruning. 200mm / 8" compass saw blade 9 teeth per inch for more detailed work.150mm / 6" metal hacksaw blade 24 teeth per inch for cutting metal pipes and rods.
EAN Barcode | 3253560200923 |
- Standard Delivery* - £1.99
*UK Mainland only. Order before 3pm for Next Day Delivery. Additional charges may apply for remote or offshore areas.
