Earn extra with DOUBLE Points on all purchases!
Stanley FatMax Thru Tang Bevel Edge Chisel Sets
- Shatter proof handle with soft grip panels for comfort
- Thru tang with steel striking cap, takes a hammer blow
- EN31 fully ground and finished ball-bearing steel blade
Made very much for the professional end user, these chisels represent a great deal of research and development on the part of Stanley. The shatterproof handle is longer than most other chisels on the market for maximum control. It also incorporates soft feel urethane panels for comfort in all situations, and has been given a steel striking cap should anyone be tempted to use a hammer rather than a mallet, at least the option is available if the mallet has gone walkabout. As one would expect, the same high level of attention has been paid to the blade. Made from EN31 high quality ball-bearing steel and then fully ground and finished for an excellent edge. Available as a set of 3 (12,18 and 25mm) or a set of 5 (6,12,18,25 and 32mm).
