Stanley FatMax Pro Autolock Tape 8m/26ft
103259
From £34.44 £28.70
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Wednesday 23rd Apr
  • Two additional clip on end hooks for greater versatility
  • Patented reverse lock mechanism for greater control and increased blade life
  • Mylar coated blade, ten times more resistant to abrasion
  • BladeArmor® coating on the first 80mm for double the blade life
  • 3m blade standout for increased reach and easier measuring
  • Detachable hook and bi-material case with belt hook
  • Length: 8m/26ft; blade width: 32mm
  1. Stanley FatMax Pro Autolock Tape 8m/26ft
Total:
£140.10 £116.75
The Stanley FatMax Pro Autolock 8m/26ft Tape (8m/26ft) has a patented and innovative automatic blade-lock mechanism. Unlike other tapes, which you pull out and then lock, the blade of an Autolock tape is held in place as you extend it. This allows for quick and easy measuring even on your own. Pressing the lock button retracts the blade. You can switch off the Autolock feature and use the tape in a normal self-retracting mode.
The mylar coated blade is up to ten times more resistant to abrasion than normal lacquered blades. The first 80mm of the blade has BladeArmor® reinforcement offering extra protection to the most vulnerable part of any tape. The 32mm wide blade has a 3m standout for increased reach. The ABS impact resistant case has a moulded rubberised grip for comfort and a secure hold even in wet conditions.
Stanley's FatMax Autolock Tape also comes with two additional, interchangeable hooks. These simply clip onto the standard hook to make measuring even more versatile and efficient. The XL hook is an oversized hook allows you to hook the tape side-on to the structure, meaning no need to twist the tape and reducing inaccurate measurements. There is also a magnetic hook for easy one-handed measuring of steelwork and scaffolding. Secure hook storage on the body of the tape measure keeps the interchangeable hooks ready for use.
