Stanley Folding Pocket Knife
- Attractive, epoxy coated, die-cast, metal body
- Simple spring mechanism which enables the blade to be locked securely
- Supplied with 2 x 5901 blades, contained in the handle
Stanley 10-598 attractive, epoxy coated, die-cast, metal body, folding pocket knife with a simple spring mechanism which enables the blade to be locked securely in the extended position or stored safely within the body. Supplied with 2 x 5901 blades. Spare blade contained in the handle.
EAN Barcode | 5000366105987 |
- Standard Delivery* - £1.99
