Stanley Multibit Stubby Screwdriver with 6 Bits
- Supplied with six 1/4" hexagonal bits stored in the screwdriver's end cap
- Comfortable bi-material handle provides added torque
- Easy to use ratchet mechanism, screw & unscrew direction twist action
- Suited to all tight or restricted access screwdriving applications
A really useful addition to any tool kit. Compact enough not to take up too much space and bright enough to be easily found in the depth of your tool bag. The Stanley Multibit Ratchet Stubby Screwdriver comes complete with six 1/4" hexagonal bits stored in the screwdriver's end cap for quick and easy bit changes. The bi-material handle is comfortable to use and provides added torque and easy access to bit storage, while the magnetic bit holder ensures that bits are held securely in when in use. The easy to use ratchet mechanism has screw and unscrew direction twist action. Suited to all tight or restricted access screwdriving applications around the home, office or work site.
EAN Barcode | 3253560663582 |
- Standard Delivery* - £1.99
