VDE certification requires that these screwdrivers are tested to 10,000V and are rated for safe working use up to 1,000V AC. However simple the electrical work being carried out, VDE certified tools should be used. These screwdrivers feature chrome vanadium steel blades with hardened tips for durability and long service life. The tapered, slim insulation allows access without modification and safe working to 1,000V. Each screwdriver has a comfortable, bi-material handle for excellent torque transmission and control.
This 5 piece set comprises:
Slotted:
0.4mm x 2.5mm tip x 75mm
0.8mm x 4.0mm tip x 100mm
1.0mm x 5.5mm tip x 125mm
Pozidriv:
PZ1 x 80mm
PZ2 x 100mm
Tested to 10,000V for safe working up to 1,000V AC
Chrome vanadium steel blades
Hardened tips for durability and long service life
Bi-material handles for excellent torque transmission
