The Starrett Fast Cut Bi-Metal Holesaws provide a smoother, faster cut on a wide range of materials, when compared to the previous constant pitch saw. Improved tooth material and 5.5 TPI/25mm tooth form for enhanced heat and wear resistance and greater product life. Specifically suited to cutting stainless and mild steel sheet, they will also cut through tubes with a wall thickness of up to 3mm (1/8in). Specification: Cutting Depth: 41mm.
Starrett
Starrett Fastcut Bi-Metal Holesaws
- 102 mm
- 105 mm
- 108 mm
- 111 mm
- 114 mm
- 121 mm
- 127 mm
- 133 mm
- 140 mm
- 14 mm
- 152 mm
- 16 mm
- 17 mm
- 19 mm
- 20 mm
- 21 mm
- 22 mm
- 24 mm
- 25 mm
- 27 mm
- 29 mm
- 30 mm
- 32 mm
- 33 mm
- 35 mm
- 37 mm
- 38 mm
- 40 mm
- 41 mm
- 43 mm
- 44 mm
- 46 mm
- 48 mm
- 51 mm
- 52 mm
- 54 mm
- 56 mm
- 57 mm
- 59 mm
- 60 mm
- 64 mm
- 65 mm
- 67 mm
- 68 mm
- 70 mm
- 73 mm
- 76 mm
- 79 mm
- 83 mm
- 86 mm
- 89 mm
- 92 mm
- 95 mm
- 98 mm
| Holesaw Diameter | 102 mm |
| Web Attribute Set | Holesaws |
| EAN Barcode | 7891265005267 |
