Titebond
Titebond Solvent Free Construction Adhesive
SKU: 409001
£9.58
£7.98 Excl. VAT
  • Blend of polymer emulsions, for interior and exterior use
  • Suitable for wood, metal, plastics and some rubbers
  • Solvent free, use with polyurethane and polystyrene
  • Setting time 6-24 hours
  • Tube 296ml(10oz) & 215mm length(excluding nozzle)
A solvent free adhesive designed to give a strong bond between wood and most other building materials, hence the name. Excellent for the fitting of applied decorative mouldings and panels and a wide range of materials as diverse as wood, metal, masonry and types of plastic, plasterboard, polyurethane and polystyrene applications. Some clamping or bracing may be necessary for heavier items whilst drying. For use in a skeleton gun. Tube 296ml(10oz) & 215mm length(excluding nozzle)
Setting Time 6-24 hours
Suitable For Wood Metal Some Plastics Masonry Rubber Leather
Adhesive Type Blend of polymer emulsions
Pack Quantity 1
Web Attribute Set General Woodworking Adhesives
EAN Barcode 37083074710
