Earn extra with DOUBLE Points on all purchases!
Tormek T-4 Original Sharpening System With HTK-906 Hand Tool Kit
- Compact, high quality sharpening system with 200mm wetstone
- Sharpen your plane irons and chisels with a perfectly square edge
- Sharpen hand tools, knives, scissors, woodturning and woodcarving tools
- Comprehensive kit of 6 jigs for sharpening common hand tools
- NVR switch, providing safety in the event of an interruption of power
- Stainless steel shaft
- SP-650 Stone Grader and AngleMaster included
- Strengthened housing for improved sharpening results
- Solid zinc, precision machined top incorporating the handle
- 8 year warranty (5+3)
Tormek T-4 Original Sharpening System With HTK-906 Hand Tool Kit is the ultimate solution for all your sharpening needs. This versatile system is designed to provide precision and efficiency, ensuring your tools are always in top condition. The Tormek T-4 features a powerful motor and a durable construction, making it perfect for both professional and home use. The HTK-906 Hand Tool Kit includes a variety of jigs and accessories, allowing you to sharpen a wide range of hand tools with ease. Whether you're a woodworker, a chef, or a DIY enthusiast, the Tormek T-4 Original Sharpening System will help you achieve razor-sharp edges and prolong the life of your tools.
Tormek T-4 Water Cooled Sharpening System
The Tormek T-4 features a zinc cast top incorporating the machine's key components: the main shaft, Universal Support and motor assembly, which results in superb accuracy. Two sleeves hold the Universal Support in the zinc cast top, this along with the locking device and tight tolerances guarantees perfect results every time.
The T-4 is ideal for sharpening cabinet making hand tools, knives, scissors and woodcarving and turning tools. It comes supplied with two useful accessories, the first of which is the SP-650 Stone Grader that can be used to keep the stone cutting efficiently as well as changing the surface from a (220g) coarse cut to (1,000g) fine. The equivalent of 2,500-3,000g can be achieved on the leather wheel. The second is the AngleMaster, an adjustable device used to set the correct angle for grinding plane and chisel blades. Magnets on the reverse side of the AngleMaster mean that it is easy to store it conveniently on the steel machine plate.
Also supplied is the unique Tormek Handbook, where all the information that is required to shape, sharpen and hone your tools to perfection can be found. The T-4 uses a powerful, industrial AC motor and the shaft supporting the wheels is made from corrosion resistant stainless steel. It also includes the Tormek Handbook.
8 year warranty (5+3) Tormek extended warranty of 5 years + 3 extra years upon registration.
Tormek HTK-806 Hand Tool Kit
Packed in a high quality storage case with an opaque lid and foam insert the HTK-806 is a comprehensive kit of 6 jigs for sharpening common hand tools. The jigs enable you to sharpen a wide range of tools such as axes, scissors, long chef’s knives, short bladed knives, carving and butt chisels, pocket knives and garden shears.
The Tormek HTK-906 Hand Tool Kit includes the following:
KJ-45 Centring Knife Jig for general and short knives
KJ-140 Wide Centring Knife Jig for long chef’s and filleting knives
SVX-150 Scissor Jig for scissors and shears
SVS-38 Short Tool Jig for carving and butt chisels
AX-40 Axe Jig for axes and hatchets
SVM-00 Small Knife Holder for carving knives and pocket knives
HTK-00 Storage Tray for Hand Tool Kit
TC-800 Storage Case
For more tips on sharpening please see Tormeks YouTube channel.
