Trend Beech Loose Tenons
- Solid beech loose wood tenons
- FSC certified beechwood
- Create accurate, strong and sustainable joints
- Feature full length, long grain glue grooves
- For use with a router and mortice jig
- Compatible with Festool Domino Morticing System
Made of FSC certified beechwood, these Trend solid wood loose tenons can be used with a router and mortice jig, or with the Festool Domino morticing system. They combine the properties of traditional dowels and jointing biscuits, for accurate, strong and sustainable joints. Perfect for furniture making and other carpentry tasks, these tenons feature full length, long grain glue grooves which hold more PVA and allow excess glue to exit, for maximum adhesion. The larger contact surface improves alignment and joint stability.
5 & 6mm are supplied in packs of 100.
