Trend Door Skate
109649
Special Price £41.98 £34.98 was £44.98 £37.48 Save £3.00 £2.50
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Wednesday 16th Jul
  • Move doors or sheet materials around with ease
  • 75mm wheels with ball bearings
  • Easy to use, let the Skate take the strain
  • Maximum sheet/door size 2,400 x 1,200mm
  • Maximum sheet/door weight 226kg
  • Maximum sheet/door width 45mm
  1. Trend Door Skate
Total:
£132.82 £110.68
Stop struggling to move that 8x4 sheet or that door. Stick a Trend Door Skate under it and wheel it (practically) effortlessly to where you want it. The Trend Door Skate allows door and sheet material to be moved around the workshop more easily. As is always the case, the simplest things work best. Well designed, it features two 75mm diameter polyurethane wheels with ball bearings, for smooth operation. There is a 45mm gap between the wheels. The gap is in the form of a shallow vee; so your door or sheet naturally sits centrally between the wheels.
For heavier doors or more awkward sheet materials, you can use two together placing them at either end so you don't need to worry about balance. Each skate is suitable for loads up to 226kg.
