Trend Router Pod Universal Safety Stand
109651
From ÂŁ11.98 ÂŁ9.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Saturday 22nd Mar
  • Perfect place to park or store any router
  • Router upright and ready to use
  • Accommodates cutter and guide bush
  • Prevents laying of router on side or head
  • U-shape design to allow easy router placement
  • Non-slip rubber feet
  • Interlocking, double stack for long cutters
  • Prevents cutter damage to the workbench
  • Made from ABS plastic
  • Compatible with all makes of routers
  1. Trend Router Pod Universal Safety Stand
Total:
ÂŁ78.34 ÂŁ65.28
The Trend Router Pod is a simple universal router safety stand for use with any router. It is the perfect place to park or store your router in between jobs. Using the Router Pod means you don’t have to lay your router on its side. The Pod prevents potential damage to your bench top, work surface and the cutter. The horseshoe shape design allows you to place your router quickly and easily. The Pod’s base is fitted with non-slip rubber feet. At 45mm high it safely accommodates a cutter and guide bush. If using long cutters; the Pods interlock for stacking.
Size: 155mm x 175mm
Depth: 45mm
Internal diameter: 65mm
