From £434.98 £362.48
Low Stock
- get it Tuesday 28th Mar, order within and choose Premium delivery. Delivery info
  • 2,300W router for professional woodworkers
  • High-performance with many advanced features
  • Twin LEDs illuminate the area around the cutter
Customers Also Bought
Total:
£685.12 £570.93
The Trend T12EK Router is a high-performance plunge router for professional woodworkers. Methodically designed and engineered, it comes with many advanced safety features.
The 2,300W motor delivers consistently high power, torque and speed, and features soft-start to prevent kick-back. The 80mm plunge depth opens up many opportunities for deep cutting applications. Phosphor-bronze bushes, ensure a smooth plunge action. The auto-lock plunge lever allows you to easily and safely operate the plunge without releasing the handles. The ergonomic designed handles support a natural wrist position, reduce strain, and increase control.
The seven-stage variable speed control from 9,000 to 22,000rpm, allows you to match the cutter diameter to the material for perfect results. For your essential safety the automatic power shut-off prevents the router from accidental start-up if the trigger lock-on switch is engaged, and the power supply is lost and restored or interrupted.
Micro adjustable height and side fence come as standard, along with a spindle lock, which simplifies cutter changes. Twin LEDs illuminate the area around the cutter improving safety and accuracy in low-light situations, or the use of a jig is casting shadows.
The T12EK base configuration includes a standardised fixing pattern of holes that allow the T12EK to be attached to a range of compatible, jigs and accessories. A precision centring system uses a unique guide bush centring pin and adaptor plate to ensure perfect concentricity between cutter and guide bush for pinpoint accuracy with routing jigs.
The top-mount cyclone extraction features an enhanced dust adapter, which efficiently clears the waste. Its positioning ensures greater visibility and helps prevent extraction hoses from ‘snagging’.
Supplied with: side fence, 30mm guide bush, guide bush adaptor plate, 1/2" collet, centring pin, top-mount extractor adaptor, Cyclone dust adapter and storage case.
Note: This router is fitted with an Anti Restart Safety Switch and is incompatible with a seperate external NVR switch.
  • Variable speed control from 9,000 to 22,000rpm
  • 80mm plunge depth for deep cutting applications
  • Phosphor-bronze bushes, ensure a smooth plunge
  • Micro adjustable height and side fence as standard
  • Automatic power shut-off prevents accidental start-up
  • Precision centring system for guide bush
  • Top-mount cyclone extraction efficiently clears the waste
Warranty Trend 3 Year Warranty (Registration Required)
Trend offer an extended warranty of 3 years
For more information and to register your product visit the Trend website
Register now
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
