Trend Varijig Adjustable Frame System
501663
From £104.98 £87.48
4 Reviews
Dispatching Soon
- Email me when available
  • Adjustable guide for routing squares and rectangles
  • Cut recesses, grooves, slots, create panels and kitchen doors
  • Max working area 600 x 600mm
  • Easy and simple to adjust, anti tilt shoe supplied
  • Use guide bush with a minimum 8mm spigot (not supplied)
  • C/w 4 lengths of 700mm extrusion with metric/imperial scales
  • Supplied with anti-tilt shoe, fixing screws and 4 x corner brackets
  1. Trend Varijig Adjustable Frame System
Total:
£331.02 £275.85
Fully adjustable frame for rectangles and squares, use as a guide for the router. Cut recesses, grooves and slots, suitable for creating panels, great for making kitchen doors. The kit contains four lengths of 700mm extrusion with dual metric/imperial scales. The working area is 600 x 600mm. Frame can be easily adjusted using the clamp screws. Standard clamps can be used to clamp to your work piece. Use guide bush with a minimum 8mm spigot (not supplied). Supplied with anti-tilt shoe, fixing screws and 4 x corner brackets.
4.80 4
