More deals added in
Have you clocked our Christmas Countdown deals?
From £6,834.00 £5,695.00
Available to Order
- contact us for a personalised quote
  • IMPORTANT: Please contact Axminster Tools to arrange a more detailed explanation of the Trend Smartbench and the options available to suit your individual needs. Please call 03332 406 406 to speak with the Axminster Business Services team to arrange the consultation, or fill in the enquiry form further down the page. Please note: this machine is delivered directly from the manufacturer.
  • Highly accurate CNC routing for the workshop or on site
  • Easy to use; intuitive touch screen control
Customers Also Bought
The world's first industrial, portable, 3D CNC router
If you're looking for premium performance and unmatchable accuracy from a CNC, you can achieve pro status with the next generation, Trend Yeti CNC Precision Pro SmartBench.
What makes the Precision Pro even more unique is with its autonomous cutting, you can work hands-free!
Excellent capabilities
Bringing large format cutting to small spaces, the Precision Pro processes up to 2,500mm (98.43") x 1,250mm (49.2") sheets with full edge to edge capability of up to 152mm (6").
Real time spindle features
The real time spindle load display allows access to all the cutting information you need while the job gets done. The overload feature monitors speed, temperature, and current in real time.
Reliable and repeatable performance
The Precision Pro repeatedly produces finished parts within its stated tolerance. It comes complete with a twin lead screw to improve Z axis rigidity.
Quality and accuracy
Precise machinery at home or on site, with an accuracy of +/-0.5mm or better. The laser X/Y datum makes setting a job start point efficient and accurate.
Excellent usability
Operation could not be simpler. The intuitive touchscreen control unit can receive jobs or instructions via WI-FI or USB. Set up and apps make control and processing effortless.
Portable and quick setup
Assembles in just three minutes or less. Dissasembles just as effortlessly. Easily store in the van or the tightest of workshops and industrial units.
Cuts through multiple materials
From timber based materials to hard and soft plastics. From soft metals to solid surface materials, there are not many materials that the Precision Pro can't cut.
Why not book a visit with our knowledgeable team?
If you're interested in this machine for your business we can talk you through the features and benefits in detail and recommend the best options for you.
Important: If you would like further detailed information on the CNC Precision Pro SmartBench, simply fill in the attached enquiry form and one of our sales team will be in contact to discuss your requirements. This machine is delivered directly from the manufacturer.
SmartBench finally brings CNC routing capability into your workshop or on site. Perfect for Furniture Making, cabinetry, panelling, interior design, boat building, caravan fitting, camper fitting, car restoration, sign making, carving, and much more - SmartBench allows new levels of creativity, accuracy and time-saving as well as efficient use of materials.
SmartBench works on material sizes up to 2,500mm by 1,250mm (8’ x 4’) with an impressive cutting depth up to 152mm (6”) – meaning the machine is equally at home drilling, cutting shapes, machining components or even making intricate carvings.
It is perfect for a wide variety of materials, including wood, plywood, MDF, Corian, Acrylic, aluminium and many more. The revolutionary design gives a high degree of accuracy over the entire work surface. Operation could not be simpler. The touchscreen control unit can receive jobs or
cutting instructions via wi-fi or USB. SmartBench uses nc or gcode files and can be supplied with highly intuitive software which can be used on a Mac or PC. SmartBench fits into a van for transport to site, where it can be set up and ready to go in just a few minutes. Where workshop space is at a premium, it is easy to store when not in use. The unit disassembles in seven easily transported parts -making it easy for one person to handle.
X axis travel: 1,265mm
X max speed: 6m per minute
Y axis travel: 2,515mm
Y max speed: 6m per minute
Z axis travel: 152mm
Z max speed: 2m per minute
X & Y Axis: Rack and pinion
Z Axis: Twin lead screw
Max depth of material: 152mm
Accuracy: +/-0.5mm or better
Software: Any CAM software with a GRBL post processor
File Types: .nc or .gcode
Overall: L 2,740mm x W 1,650mm x H 1,350mm
Nett Weight: 100kg
  • Easily to transport and set up; fits in a van
  • Large capacity; max area 2,500mm x 1,250mm (8' x 4')
  • Portable; sections made to be handled by one person
  • Perfect for furniture making, cabinetry, panelling, interior design, boat building, caravan fitting, camper fitting, car restoration, sign making, carving, and much more
Warranty 1 Year Warranty
