TSO MTR-X Multifunction Precision Triangle Set
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Pre-set precise angles between 0.90°
- CNC machined, anodised finish with etched markings
- 5 x 20mm dog holes for attaching to 20mm grid system
- Attach to guide rail as a an angle guide
- Add reference pins and use as a square
- Attach the clamping angles and use for accurate assembly
- Use to check and calibrate machine fences
TSO Products Aligning Guide Rail Connectors GRC-12 (Pair)Special Price £62.99 £52.49 was £69.98 £58.32 Save £6.99 £5.82
TSO Products DBF-45 BigFoot v2.0 Base Support Festool DOMINOSpecial Price £93.48 £77.90 was £109.98 £91.65 Save £16.50 £13.75
TSO TPG 30/50 Parallel Guide System SetSpecial Price £373.90 £311.58 was £439.88 £366.57 Save £65.98 £54.98
The MTR-X is a very precise triangle with an angle setter, that is used as a protractor or a variable angle fence for setting, laying out, calibrating tools or to aid assembly. Use on its own or attach directly to a Festool, Makita, Kreg or Milwaukee guide rail or utilise the 20mm dog holes for use on a grid system bench top.
Measuring 246mm x 346mm the MTR-X is CNC-precision machined from cast aluminium with an anodised finish for durability that gives a non-marring finish. The graduations are laser engraved on both sides, making the scale easier to read even in poor light. The very precise angle setter allows you to set with a positive lock, any angles between 0-90°. There are 5 x 20mm dog holes drilled into the triangle and it is supplied with 2 dogs to allow the MTR-X to be attached to a Festool MTF or similar grid system and used as a fence. Also supplied are Edge Index Pins that can be attached to the face of the triangle as a reference shoulder, so you can use it as a square.
Clamping angles are also included so that you can attach the triangle with clamps to help assemble your project. Attach to a Festool, Makita, Kreg, Milwaukee or similar guide rail supplied with the adaptor and the triangle turns into a very accurate angle guide, the low profile locking knobs mean that these do not interfere with a track saw when cutting. Calibrating tools is also another feature due to it's compact size. Ideal for tasks such as a fence squaring or setting mitre saw angles or a mitre gauge.
Made in the USA and verified square with automated CMM to .001' along with full length.
Supplied with: 2 x TSO Chamfer close fit dogs, guide rail connector (for Festool, Makita, Milwaukee and Kreg) 2 x M6 short index pins, 2 x M6 long index pins, 2 x 125mm clamping angles and foam systainer insert.
EAN Barcode | 850043733010 |
Model | MTR-X |
Nett Weight | 3.2kg |
Overall L x W x H | 247 x 40.6 x 6.4mm |
- Standard Delivery* - Free
