TSO TPG Drop On Guide Rail Adaptor for Festool
- Suitable for Festool guide rails
- Adaptor drops on for quicker set-up and removal
- Fits both RH and LH tracks
- Secured using knobs supplied with Parallel Guide kits
TSO Products Aligning Guide Rail Connectors GRC-12 (Pair)Special Price £62.99 £52.49 was £69.98 £58.32 Save £6.99 £5.82
This TPG adaptor is designed for Festool guide rails and will simply drop onto the rail for fast connection of the TSO TPG 30 and 50 parallel guide systems.
The adaptor can be used on RH and LH tracks, simply drop on the rail secure using the knobs from the Parallel Guide kit giving a fast and simple set up.
TPG Adapter secures to your guide rail using the same innovative keystone alignment feature and torpedo nut found on the TSO GRC-12 Guide Rail Connectors, ensuring rock-solid attachment that's easy to install and remove. The TGP is intended to be used when the GRS-16 Guide Rail Square has not been purchased beforehand.
Note: Previous versions of the TPG Adaptor included Comfort Grip Knobs and Centering Spacers, along with a 3mm Ball-Hex Driver. These accessories are now included in the TPG-30 and TPG-30/50 Sets, and no longer included with each TPG adaptor.
EAN Barcode | 859448007726 |
- Standard Delivery* - Free
