One of the most versatile and popular SK100 jaw sets suitable for the SK100 chuck. The Type C jaws expand into a 70mm recess and have a stepped shoulder for an internal grip onto a 56mm spigot diameter. These given dimensions are when the jaws form a true circle and offer the best grip. There is substantial variation 52mm to 66mm internally and 66mm to 80mm externally. Although the more the jaws expand, the less of a circle they form. The Type C jaws are especially useful for small bowls and end grain work such as boxes and goblets. In addition, a wide range of direct loading accessories are available. These include screw chucks/faceplate drives, faceplate rings and Morse taper carriers. As with all our dovetail jaws they simply bolt onto the Accessory Mounting Jaws. Made from stainless steel to protect against corrosion.
Please note: These jaws are suitable to use with the GK100, SK100 and SK114 Chuck. If putting 100mm jaws onto the SK114, the additional 100mm accessory mounting jaws will be needed.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Intended Use For creating dovetail recesses or spigots during woodturning.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511020768
