Axminster Woodturning
Axminster Woodturning Dovetail Jaws Type M
SKU: 410174
€85,00
  • Potential gripping range: Internal 91mm to 117mm
  • Potential gripping range: External 118mm to 134mm
  • Great for both platter and hollow form turning
  • Drawing dimensions taken when jaws form true circle
  • Made from stainless steel to protect against corrosion
  • Suitable for the GK100, SK100 and SK114 Chucks
  • Made in the UK
SK100 Dovetail Jaws Type M; where M stands for Mega, maybe a clue as to their intended function. The Type M jaws are one of the largest available for the Axminster precision chuck system. When at a true circle the external diameter is 125mm and the internal 100mm by 16mm deep. These are the jaws to choose for turning large platters and bowls from hefty blanks. The possible grip range is internal 91mm to 117mm and external 118mm to 134mm. Bear in mind, the greater the diameter, the less circular the jaws become, although the holding power remains very strong. Made from stainless steel to protect against corrosion.
Recommended for GK100, SK100 and SK114 chucks. If putting 100mm jaws onto the SK114, the additional 100mm accessory mounting jaws will be needed.
Proudly made in the UK
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use For creating dovetail recesses or spigots during woodturning.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511020843
