UJK Sheet Material Rule - 1,220mm
- 1,220mm long spans the full width of an 8x4 sheet
- For accurate marking out and guide rail positioning
- Hardened stainless steel with pearl chrome anti-glare finish
- EC Class 1 standard for guaranteed accuracy
- Permanently etched, easy to read black filled graduations
- Metric graduations in millimetres top and bottom edges
Measuring sheet material on a regular basis in preparation for cutting to size can be a frustrating process. Tape measures have limitations when it comes to accuracy and rules are generally not long enough. At 1,220mm the UJK Sheet Material Rule spans the full width of an 8 x 4 sheet. This is a most useful aid when positioning your guide rail prior to sawing or simply marking cut lines or divisions.
This 1,220mm rigid, hardened stainless steel rule is 35mm wide and 1.5mm thick with an anti-glare pearl chrome finish. It features millimetre markings on the top and bottom edges, with a conversion chart on the back. The permanently etched graduations with black infill are clear and easy to read. The rule reads zero from the left-hand end and features a hanging hole at the opposite end. EC Class 1 standard for guaranteed accuracy.
EAN Barcode | 5052511123575 |
EC Accuracy | Class I |
Graduations | Metric Only |
Rule Length | 1,220 mm |
- Standard Delivery* - £4
