UJK 10mm Pre-Drilled Router Table Insert for Triton TRA001
- UJK 10mm aluminium router table insert plate
- Pre-drilled to fit the Triton TRA001 1/2" Router
- Threaded lead-in pin
- To fit 230 x 306mm aperture
- Twist lock insert ring supplied with wrench
- Range of central insert rings available
This 10mm UJK router table aluminium insert plate is pre drilled specifically for the Triton TRA001 1/2" Router, for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. The insert plate will accommodate the Triton TRA001 1/2" Router with pre-drilled holes to fit perfectly. It is supplied with a removable central insert ring with a 38mm diameter hole with a range of other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing.
The UJK router table insert for Triton TRA001 will also fit: TRA002 and MOF001.
EAN Barcode | 5052511138883 |
- Standard Delivery* - Free
