UJK Edge Breaking Router Cutters - 1/4" Shank
- Create a flawless woodworking finish
- Ensures perfect arris removal for a clean, professional look
- Manufactured from EN8 steel, coated with Xylan to reduce friction, prevent build-up, and extend lifespan
- Essential prior to applying paint or varnish
- Available in 1/4" shank and multiple radii (1mm to 6mm) for exact and controlled rounding
- Proudly designed and made in Britain
UJK Portable Trim Router TableSpecial Price ÂŁ174.98 ÂŁ145.82 was ÂŁ249.98 ÂŁ208.32 Save ÂŁ75.00 ÂŁ62.50
UJK Straight Router Cutters D=12.7 - X=50mm - S=1/2"Special Price ÂŁ18.74 ÂŁ15.62 was ÂŁ24.98 ÂŁ20.82 Save ÂŁ6.24 ÂŁ5.20
Axminster Professional Forged Flat Bar Clamp 200 x 80mmSpecial Price ÂŁ11.68 ÂŁ9.73 was ÂŁ15.58 ÂŁ12.98 Save ÂŁ3.90 ÂŁ3.25
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price ÂŁ66.40 ÂŁ55.33 was ÂŁ89.98 ÂŁ74.98 Save ÂŁ23.58 ÂŁ19.65
Axminster Professional Combination Square Metric 300mmSpecial Price ÂŁ14.98 ÂŁ12.48 was ÂŁ18.88 ÂŁ15.73 Save ÂŁ3.90 ÂŁ3.25
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)Special Price ÂŁ24.98 ÂŁ20.82 was ÂŁ29.98 ÂŁ24.98 Save ÂŁ5.00 ÂŁ4.17
The UJK Edge Breaking Router Cutter, the ultimate tool for achieving a flawless finish on your woodworking projects, this cutter is designed to deliver precision and reliability every time.
Don’t leave a sharp edge of wood unfinished! A sharp edge or corner can be uncomfortable to handle, may splinter, and will not take a finish well. Rounding over sharp edges or creating a slight chamfer on an edge, known as "removing the arris” will solve these problems.
The British made, UJK Edge Breaking Router Cutter, allows you to can achieve exact and controlled rounding. Unlike standard rounding over cutters, the UJK Edge Breaking cutter has cutting edges that gradually recede from the radius at the top and near the bearing to ensure no corner lines remain. Available in 1/4" shank and in multiple radii from 1mm, 1.5, 2, 3, 4, 5 and 6mm, this cutter ensures perfect arris removal, giving your work a clean and professional look.
As the UJK Router Cutter range grows, all UJK cutters are proudly designed and made in Britain. Manufactured from EN8 steel and coated with Xylan to reduce friction, prevent build-up, and extend the cutters lifespan. UJK's commitment to innovation is evident in every detail of this router cutter.
