UJK M2 HSS Premium Brad Point Drill Bits
- Premium UJK Brad Point drill bits, made in Austria
- Higher cutting edge on the spur - scribes the hole for a cleaner cut
- Precision CNC machined centre point for greater accuracy
- Four Flute spiral design for superior guidance, faster waste clearing
- Manufactured from M2 HSS Steel
- Excels at cutting hardwood
- Can be used on softwood, laminated boards, MDF, or acrylic glass
UJK HSS Countersink with Hex Shank - 12.4mmFrom £17.98 £14.98
UJK Wave Forstner Bit Set Metric 5 PieceFrom £104.98 £87.48
Upgrade your drill bits with the UJK M2 HSS Professional Brad Point Drill Bits. Made in Austria, these premium UJK drill bits advanced design features are designed for efficient and superior wood drilling. Excelling in hardwoods but also performing well with softwood, laminated boards, MDF, or acrylic glass.
The advanced design of these brad points is remarkable, featuring a 0.4mm higher cutting edge on the two spurs, its knife-like tips scribes the hole before the before the inner parts of the cutting edges plane off the base. By cutting the outer edge first, the lip ensures that the wood fibres are sliced cleanly, for a splinter free cut. The CNC machined centre point ensure precise start and guidance.
The spiral design with four flutes within, ensures better guidance and more effective waste removal. Allowing precise, clean cuts, with faster clearing, reducing drilling time and effort, and ensuring greater accuracy.
Manufactured in Austria, from high-grade M2 HSS steel, these drill bits offer durability and long-lasting performance.
Perfect for any type of workshop, the UJK M2 HSS Professional Brad Point Drill Bits are a premium addition to your toolkit, offering superior quality and performance for all your woodworking projects.
