The UJK Hook Stop, a versatile solution for any MFT bench. Designed for flexibility, you can place it anywhere that suits your project needs. Whether you're planing wood to perfection or clamping down for stability, the UJK Hook Stop is your go-to accessory.
Compatible with hand planes and power planers, biscuit jointers, and the Festool Domino. It allows for vertical and 45 planing against the body. For secure clamping, pair it with UJK Cam and Wedge Clamping Set and for thicker wood, simply stack multiple stops for a firm hold.
The UJK Hook Stop stands out with its unique hook feature, ensuring your material is located easily and stays put for the most precise work. It's a modern evolution of the traditional bench stop, with one round hole and two elongated for use with an MFT workbench. The three holes also enable 45 usage, adding to its handiness.
It's more than just a stop; it's a reliable, flush support against your wood, accessible even when clamping isn't suitable or accessible. Designed for use with MFT tables and UJK low profile dogs, the UJK Hook Stop is easy to move and adjust, making it a valuable addition to any woodworking setup.
Intended Use Used in conjunction with dog holes to hold work to a workbench.
EAN Barcode 5052511136261
