This connector is used to join two UJK Parf Sticks if the bench being drilled is narrower than the stick. As in cases where a point of the 3:4:5 triangle is overhanging the edge of the bench.
UJK
UJK Parf Guide System Parf Stick Connector
| Made in Britain | Yes |
| Intended Use | Used in conjunction with the Parf Guide System to produce dog holes. |
| Web Attribute Set | Festool CMS Moduler System and MFT Table Accessories |
| EAN Barcode | 5052511126033 |
