Introducing the UJK Parf Protractor, the ultimate addition to the UJK Parf MKII Guide System, for precision woodworking. Working with the renowned UJK Parf MKII Guide System, the ingenious UJK Parf Protractor allows you to create a further series of 20mm dog holes, ranging from 0-45° and 45-90°. With precise angle measurements in 0.5° increments, offering versatility and ensuring repeatable and accurate cuts every time.
Proudly British Made at UJK HQ, the Parf Protractor guarantees accuracy and reliability. The UJK Parf Protractor features slightly varied marking holes to provide the most precise angle at each point, eliminating any chance of cumulative error. Made from aluminium with high-precision laser engraving, it ensures that every cut and angle is as exact as possible.
It can be used on the vertical rule and is compatible with a host of 20mm dog fittings and accessories. Use the UJK Parf Protractor with guide rail clamps and 20mm bench dogs to achieve multiple cuts just like the Parf Guide System, at various, precise angles,
UJK Parf MkI Parf sticks are compatible with the UJK Parf Protractor.
As with all UJK products, the Parf Protractor is made to the highest standard, embodying the reliability and quality that UJK is known for. Enhance your woodworking capabilities with this truly innovative tool and experience unparalleled precision and efficiency beyond the norm.
Intended Use Used in conjunction with the Parf Guide System to produce dog holes.
Web Attribute Set Angle Measurers
EAN Barcode 5052511137398
