Welcome to the home of UJK Parf
UJK Parf System
British-made tools designed to help makers build smarter, faster, and with total confidence
Whether you're creating custom benchtops, upgrading your workstation, or refining your joinery, the UJK Parf system offers unmatched accuracy and versatility. The British made UJK Parf range is engineered for pinpoint accuracy using Pythagorean principles and 20mm hole grid formats.
Create your custom benchtop
Add your Parf accessories
How our customers are using theirs...
UJK Parf System review photo
"A wonderfully well thought out system with clear instructions and plenty of video tutorials"
"If you're the sort of person that loves perfection you'll love this tool and it's perfectly accurate"
"I have made my first top and have a whole load of plans for jigs and pegboards using the system"
"This was my first UJK purchase and if this product is the bench mark then I'm already a fan"
UJK Parf Products
UJK Parf Mk II Guide System
The UJK Parf Mk II Guide System allows you to create multifunction table (MFT-style) tops with 20mm hole patterns based on Pythagoras' theorem. As a precision jig system, it's designed for long-term accuracy and ease of use — ideal for portable workstations, benchtops, and repeatable layouts.
Do you need angled layouts or complex grids?
UJK Parf Plus Guide System
The UJK Parf Plus Guide System combines the UJK Mk II Guide with the UJK Parf Protractor, offering enhanced versatility for angled layouts and complex grid setups. It's the go-to solution for makers who want precision and flexibility in one compact system.
UJK Parf Protractor
A precision woodworking tool designed to work seamlessly with the UJK Parf Mk II Guide System. It enables users to create 20mm dog holes at angles ranging from 0° to 90°, in 0.5° increments, allowing for highly accurate and repeatable cuts.
(519)
From £199.98 £166.65
(5)
From £249.98 £208.32
UJK Parf Protractor
(5)
From £59.98 £49.98
UJK Parf Guide System Parf Stick Connector
(3)
From £5.58 £4.65
UJK Parf Aluminium Revision Dogs (3)
(37)
From £15.58 £12.98
UJK Parf Accessories
Browse our most popular UJK Parf accessories, and more!
UJK Parf System Fence & Stop Kit
A reliable straight edge for repeatable cuts, marking, drilling, and assembly tasks. Eliminating the need to reposition bench dogs for different lengths, it is designed to work seamlessly with UJK Parf Guide System, multifunction worktops, and MFT benches. Available in 600mm and 1,000mm lengths.
UJK Super Dog
A precision, stainless steel bench dog that securely locks from fine to zero tolerance into 20mm dog holes on MFT workbenches. Ensuring rock-solid stability and guarantees accurate, repeatable cuts at perfect 90° or 45° angles.
UJK 12mm Guide Dogs
Low-profile, stainless steel bench dogs - their low height is perfect for unobtrusive holding or locating of jigs and accessories on MFT workbenches.
UJK Parf Anchor Dogs
CNC-machined from stainless steel, these dogs fit precisely into 20mm holes to create secure M8 threaded anchor points for jig-making and clamping tasks.
UJK Combined Chamfer & Reamer Tool
Quickly cleans, sizes, and chamfers 20mm dog holes for a perfect fit.
UJK Parf Repeat Stop
Enables consistent repeat cuts and measurements on MFT-style benches, streamlining workflow and reducing setup time.
UJK Dog Rail Clips
Secure your guide rail firmly to 20mm bench dogs, ensuring precise, stable and slip-free cuts every time.
UJK Anti-Slip Workbench Protection Dogs
Raise and protect your workpiece. They give a secure, clamp-free hold and full surface access for accurate cutting and sanding.
UJK Parf Mk II Guide System Storage Case
A protective foam-lined case tailored to store and transport the Mk II Guide System components securely.
UJK Assembly Square
A precision-made 90° guide that acts as an extra set of hands, helping you cut, align, and assemble boxes, frames, and carcasses with speed and accuracy on your multifunction table.
UJK MFT Hook Stop
Transforms your MFT bench into a versatile workstation, giving you fast, secure support for planing, clamping, and joinery, a modern upgrade to the traditional bench stop.
UJK MFT Horizontal Quick Clamps
Lock your work firmly in place with this low-profile, slip-free design. Perfect for precise routing, sanding, sawing, or drilling on any 20mm MFT table.
UJK Parf System Fence & Stop Kit - 600mm
  5. Half Star
(41)
From £79.98 £66.65
UJK Parf System Fence & Stop Kit - 1,000mm
(47)
From £99.98 £83.32
UJK Super Dog
(79)
From £19.98 £16.65
UJK 12mm Guide Dogs (Pair)
(87)
From £9.98 £8.32
UJK Parf Anchor Dogs - M8 (Pair)
(35)
From £9.98 £8.32
UJK Combined Chamfer & Reamer Tool for 20mm Dog Holes
  5. Half Star
(102)
From £29.98 £24.98
(23)
From £79.98 £66.65
UJK Dog Rail Clip (Pair)
  5. Half Star
(111)
From £9.98 £8.32
UJK Anti-Slip Workbench Protection Dogs (8)
  5. Half Star
(56)
From £14.98 £12.48
UJK Parf Mk II Guide System Storage Case with Foam Insert
  5. Half Star
(33)
From £99.98 £83.32
UJK Assembly Square
  5. Half Star
(83)
From £29.98 £24.98
UJK MFT Hook Stop
(13)
From £24.98 £20.82
UJK MFT Horizontal Quick Clamps (Pkt 2)
(10)
From £44.98 £37.48
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
