UJK Pocket Hole Screws - Pack of 500
110528
From £29.98 £24.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £7.98
Order within for delivery by Friday 17th Jan
  • Coarse thread, suits soft woods, i.e. MDF, melamine, plywood and pine
  • Torx T20 heads, provide the best possible grip
  • Large washer head, screw is not overdriven in the bottom of the pocket
  • Washer head style provides the largest amount of surface area
  • Seats firmly in the bottom of the pocket, especially for plywood or pine
  1. UJK Pocket Hole Screws - Pack of 500
Total:
£145.72 £121.43
An excellent assortment of 500 pocket hole screws all neatly contained in a storage case.
All UJK pocket hole screws use Torx drive heads, chosen to provide ease of use and the best grip possible. The washer head style provides the largest amount of surface area to seat firmly in the bottom of the pocket, especially for plywood or pine and ensures that the screw is not overdriven. Silver zinc plated steel (waxed).
The Coarse thread screw provides greater holding power for plywood, MDF, melamine and pine. These hardened screws cut their own thread and are threaded right up to the washer head giving the maximum grab on the screw. The largest washer size (9.7mm) has been used, meaning there is no need to drive the screw through the wood. Use 25mm screws to join 13mm to 19mm thick timber, 32mm screws to join 19mm, 38mm screws to join 22mm to 32mm, 50mm for 32mm to 35mm timber and 62mm long screws to join 38mm thick workpieces. Suitable for use with pocket hole jigs including Kreg®.
Pack contains:
100 - 4.0 x 25mm
100 - 4.0 x 30mm
100 - 4.0 x 35mm
100 - 4.0 x 50mm
100 - 4.0 x 60mm
5 - TX20 bits
N.B. Please remember to always use a drill driver with a clutch, using the lowest clutch setting required to do the job.
