UJK Router Table Insert for Trend T14
- UJK 10mm aluminium router table insert plate
- Pre-drilled to fit the Trend T14 1/2" Router
- Threaded lead-in pin
- To fit 230 x 306mm aperture
- Twist lock insert ring supplied with wrench
- Range of central insert rings available
This 10mm UJK Router Table aluminium insert plate is pre drilled specifically for the Trend T14 1/2" Router, for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. The insert plate will accommodate the Trend T14 1/2" Router with pre-drilled holes to fit perfectly. It is supplied with a removable central insert ring with a 38mm diameter hole with a range of other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing.
The UJK router table insert for Trend T14 will also fit:
Trend: T8E, T10E, T11E, T12E, T14E
Elu: MOF177E
DeWALT: DW625E, DWE625E, DW262E
CMT: CMT1E, CMT2E
| EAN Barcode | 5052511141036 |
- Standard Delivery* - Free
