UJK Tapered Plug Cutter
- Make tapered plugs for a perfect fit every time
- Use to hide screw heads of to add decoration
- 4 cutting edges for smooth sided plugs
- For use in pillar drill or drill stand
- Cutting depth 18mm, 10mm shank
UJK Adjustable Universal CountersinkSpecial Price £19.98 £16.65 was £24.98 £20.82 Save £5.00 £4.17
UJK HSS Countersink with Hex Shank - 12.4mmSpecial Price £14.38 £11.98 was £17.98 £14.98 Save £3.60 £3.00
UJK Long Series M2 HSS Premium Brad Point Drill Bit - 8mmSpecial Price £21.50 £17.92 was £26.88 £22.40 Save £5.38 £4.48
UJK M2 HSS Premium Brad Point Drill Bit - 7mmSpecial Price £9.10 £7.58 was £11.38 £9.48 Save £2.28 £1.90
UJK 90 Degree Chatter Free Countersink - 13mmSpecial Price £13.58 £11.32 was £16.98 £14.15 Save £3.40 £2.83
UJK Wave Forstner Bit Set Metric 5 PieceSpecial Price £83.98 £69.98 was £104.98 £87.48 Save £21.00 £17.50
UJK Wave Forstner Cutter - 35mmSpecial Price £21.82 £18.18 was £27.28 £22.73 Save £5.46 £4.55
Achieve a perfect fit every time with the UJK Plug Cutter. Even the most carefully drilled holes can be fractionally oversized, the UJK four flute plug cutters ensure a snug fit by cutting plugs that taper in their length. The slight taper ensures a snug fit by eliminating slack, allowing you to tap the plug into place and trim any excess with a flush cut saw.
Matching timber and grain direction creates an almost seamless finish, whereas contrasting timber offers a decorative look. These plug cutters feature four sharp cutting edges that produce clean, smooth-sided plugs. Made from Chrome Vanadium tool steel, they offer a long tool life.
For use a drill press or drill stand. The optimum speed is 1,000 rpm for softwood and 500 rpm for hardwood, with a cutting depth of 18mm. Available in metric and imperial sizes.
