The UJK Compact Laminated Router Table Top is high grade birch ply with a hard wearing, low friction, phenolic laminated surface. The ply core ensures the top will remain flat throughout its working life, while the laminated top ensures workpieces glide smoothly. An extruded aluminium track inset into the tabletop includes a standard 19mm track for the use of a mitre fence and a T-track slot for other jigs and accessories. The 230 x 306mm central aperture will accept any of the UJK router table inserts as well as the UJK router elevator. The top measures 600mm x 400mm and is pre-drilled to fit the UJK Compact router table leg stand, fence assembly or optional dust collection box.
Low friction phenolic laminate surface
Aluminium extrusion track for mitre fences and accessories
Thick birch ply core, will not warp over working life
Accepts any UJK table insert
Dust collection box available
Designed to fit onto UJK Compact leg stand and fence
